Clutch helper spring
Tackled my hard-going clutch last weekend - replaced clutch cable and clutch helper spring. Helper spring was hard to get out, and it took a while to figure out how to pry the new one into place - the 101 projects book sounds a bit cryptic on the matter, but eventually one figures it out. The big problem came when I wanted to re-attach the clutch release lever and the clutch positioning lever onto the clutch release fork shaft - once the spring had snapped into place, I was about 1mm short of being able to put on the circlip that holds the entire assembly together.
Axel.
1973.5 911T Targa (RS upgraded engine)
1996 VW Passat Wagon (yawn...)
Old 07-01-2002, 10:58 AM
