Fuel tank POR 15 results ??
New project 86 930 Has been in storage since 1990
After draining the fuel I noticed a level of corrosion , the tank has now been removed
Anyone have experience using the POR15 fuel tank repair system
Suitable DIY project ? And results?
Thanks in advance for the input.
Old 01-31-2013, 04:21 PM
id911T's Avatar
I've used POR-15 fuel tank sealer on three occasions, and all three times it worked great. One of my projects has been in service for several years with 0 issues.
That said, the prep is fairly labor intensive and sealing a tank with this system takes significant time once you've cleaned, etched, dried, etc. Still, it's the only tank sealer I will use. Certain other sealants (Kreem comes to mind) don't handle today's fuels very well and will eventually come off.
Just don't rush the prep. The POR product comes with very complete instructions.
Stephen
GruppeB #906
1970 911T
Old 01-31-2013, 04:53 PM
E Sully's Avatar
It is not reccommended for CIS tanks with the plastic swirl pot. It may not adhere to the plastic and peel off clogging the tank.
Ed
1973.5 T
Old 01-31-2013, 05:01 PM
jsveb's Avatar
Pictures
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 01-31-2013, 05:40 PM
SchnellSchweitz's Avatar
I actually used it successfully on the inside of my tank, which included a plastic swirl pot. I did so after doing some research on others who have done this as well.
They found Por15 does not adhere to the plastic and, therefore, cannot peel. This is was what I found. My swirl pot was not damaged by the cleaner either. It remains a bright and shiny orange to this day.
I did, however, make an effort to keep the chemicals out of the swirl pot during application.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 01-31-2013, 07:02 PM
NeedSpace's Avatar
Check you tank carefully. Keep in mind it is galvanized so it could be OK. When I took my tank out, I realized what I thought was corrosion was just old cruddy gas. I cleaned it out with purple power and a chain. My tank is original and from 1976.
That said, I know quite a number of people who have used POR 15 with great long term results, however, none had plastic bits in the tank like the swirl pot.
Old 01-31-2013, 08:01 PM
Yes, the tank is Galvanized I assume Possibly the degreaser and chain could be worth a try
Could you desire the process that was successful for you ?
Old 01-31-2013, 09:18 PM
NeedSpace's Avatar
Here is the play by play with pics.
1976 911S – from garage find to on the road
Have handy:
1) A Full big container of Purple power
2) Hose
3) hot water
4) Chain
5) Good high powered light
6) Retractable mirror
7) Retractable magnet (to get the chain out that will get stuck)
8) Time, it took a weekend for the purple power to do its thing and the gas tank to dry. The actual work was maybe an hour or so (once the tank was out). Keep in mind, you don't want to apply heat to dry this sucker...best to let nature do its job and dry through evaporation.
The rest of the what I did are in the link above.
Old 02-01-2013, 06:46 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I used it once and not pleased with the results. My tank had a small hole. I had the hole fixed at a local radiator shop (he soldered it). As an added measure I did the POR thing, sealing the entire inside of the tank, following all the directions for prep etc. Tank held for 6 months then started leaking.
Thought It would be fixed for good.
Oh well.
Chris
73 911 E
Old 02-01-2013, 08:57 AM
Checked out
McLovin's Avatar
Did it on my 914 tank, worked great for the entire time I had the car (many years).
Old 02-01-2013, 09:26 AM
Don't use it. Clean it out the best you can, if that fails purchase a new tank and save yourself time and a headache.
Old 02-01-2013, 10:30 AM
