-   -   Dash Swap Quesiton (http://forums.pelicanparts.com/porsche-911-technical-forum/731903-dash-swap-quesiton.html)
NewPorsche91132 02-01-2013 07:09 AM
Dash Swap Quesiton
Can you put an 85 dash into an 88 911? I thought that since the assembly was different (85 you remove the windshield, 88 you don't) that you couldn't swap the dashes out.
JQ911 02-01-2013 07:17 AM
I think the aircon vents are different for the 85 vs 86-89. I am also planning to replace my dash pad and looks like the 86 is different from the 85 below, not sure though.
steveinfl 02-01-2013 08:25 AM
A few years ago I put a late 80s dash in an 84. Reverse of what you are doing. I had to cut the center vent opening larger. Enlarge a few mounting bolt holes and the early dashes have 2 defrost vents while the new one has a large metal trim piece all along the back. Some trimming may be required for that. I posted it on this forum a few years ago so u can likely find it.
javadog 02-01-2013 09:28 AM
I wouldn't do it. Look for an '86-on dash.
JR
timmy2 02-01-2013 09:36 AM
Looks good.
http://forums.pelicanparts.com/porsche-911-technical-forum/595939-my-dash-swap-964-dash-84-carrera.html
