'76 911 dash switches?
Hi, my '76 911S has the two little switches on the dash for rear wiper and headlamp washers - it has neither fitted! (the car is off the road currently so I can't check to see if they do anything)
Is this unusual?
I am wondering if the washers and wiper may have been removed over the years - or maybe those switches are given other uses where wiper/ washers aren't fitted?
Any ideas please?
Cheers
Buzz
Old 01-31-2013, 11:18 PM
The switches were not fitted to cars that didn't have the options. Either your car had the options, or a previous owner added the switches for some other purpose. Porsche made plugs to fill those holes, if you want to get rid of the switches.
JR
Old 02-01-2013, 05:16 AM
Thanks Java - are these they?
Porsche Console Trim 911 552 469 00
Old 02-01-2013, 05:53 AM
Thanks - I have just ordered 2 of the blanking plugs!
Old 02-01-2013, 06:13 AM
Alternate use
Provides a switch that looks like it should be there (hidden in plain sight), but you can use it to disable your ignition. Also, provides a way to crank the engine a short bit with no ignition to help avoid a blown airbox from a dribbling coldstart valve.
'76 2.7-->3.2
Old 02-02-2013, 12:17 AM
