-   -   Looking for source of pins for 14 pin connector (http://forums.pelicanparts.com/porsche-911-technical-forum/732045-looking-source-pins-14-pin-connector.html)
fasterlaster 02-02-2013 05:58 AM
Does anyone know where I can source out the small pins which are soldered together for the 14 pin connectors used in the engine bays? The entire assembly of what I am trying to find can be found here: Part # 11-612-113-05-M100
E Sully 02-02-2013 08:06 AM
From what I've read the pins are considered part of the wiring harness. Only way to get them is order the connector kit. You could try the Dealership or local Porsche shop to see if they have any to spare. I've had luck with the mechanic giving me spares from his collection of parts.
Porsche 911 & Carrera Gauges and Miscellaneous - Page 7
matt demaria 02-02-2013 08:49 AM
They are still listed in pet although buried. I had to by some 1 1/2 years ago. If you know a mercedes shop see if they have used harnesses. They are VDO pins and very common on Mercedes.
a&j 02-02-2013 03:00 PM
FS:Spare used 14 pin wiring harness for your project...
Fasterlaster,
Was cleaning up the 911 parts bin earlier...I have a used spare 14 pin wiring harness.
$29 shipped CONUS via USPS. PayPal or check.
Let me know if you are interested and if this one works for you. PM and/or Email.
http://forums.pelicanparts.com/uploa...1359844516.jpg
http://forums.pelicanparts.com/uploa...1359844558.jpg
mossguy 02-02-2013 03:32 PM
I refurbished a similar pinned connector for my 82 240 Volvo Station wagon and they work fine.
The pins were $14.00 apiece from the dealer, about .04 cents apiece or thereabouts for McM-Crr, although had to buy more than indeed. If this is what you need, measure them and I will send you a bunch if they are the same side as your.
McMaster-Carr.webarchive
ThomO 02-02-2013 03:50 PM
check out eagle day for connectors
Electrical
