-   -   MSD Tach adaptor needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/732181-msd-tach-adaptor-needed.html)
swade 02-03-2013 04:00 AM
I am using 2 X MSD units and 2 X Blaster coils for my twin plug ignition, will the tach read correctly or do i need an adaptor?
72 Targa
Wade
kinein 02-03-2013 06:50 AM
If you need i have one in almost new condition
kinein 02-03-2013 06:51 AM
also have msd 6 btm with tach adapter and blaster coil
Plavan 02-03-2013 07:50 AM
Short Answer- Using a OEM tach- Yes.
I sent my speedo to a shop where they made the change internally to work with a MSD box.
dipso 02-03-2013 08:43 AM
I have an OEM Tach and don't need an adaptor. Re read your MSD manual, there is a spade connector on the end of the MSD unit. The tach wire plugs directly into that and reads RPMs from the MSD unit.
It's worth a try, it worked on mine.
JohnJL 02-03-2013 05:38 PM
I've had early tachs work and not work, late tachs work and not work. My experience is hit-and miss so you might try it first before ordering an adapter.
swade 02-03-2013 11:43 PM
Thanks for the replies, I'll see if it works
W
