Alps Adventurer
Traveller's Avatar
Anyone have an 80s non-turbo ignition distributor?
A bit of a long shot, but...
Preferably disassembled so that you can take a measurement. It has to be a non-Turbo unit.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 03-05-2012, 03:27 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I have an 81 on my workbench. What do you need?
Old 03-05-2012, 07:03 PM
Alps Adventurer
Traveller's Avatar
I'm really looking for dimensions for the distributor drive gear on a 84 to 89, but if you have yours on the bench, I'm looking for
  • ID of the hole that slips over the shaft
  • the overall height (gear and flange)
  • OD of the gear section
  • OD of the flange section
  • number of gear teeth
Thanks!
All the best,
Alex
Old 03-05-2012, 07:33 PM
Bob Kontak's Avatar
Can't tell without removing the gear.
1.075" (plus or minus a few thousandths)
1.013"
0.662"
12
I can remove the gear but I need to know what you are intending to do before I go to that effort. Not that I won't help a brother out - just applying common sense.
Old 03-06-2012, 02:32 PM
Alps Adventurer
Traveller's Avatar
Thanks for taking the time, Bob.
No, don't bother removing the gear, but if you can use the ID jaws of your digital caliper, a rough ID at the bottom of the gear will do.
All the best,
Alex
Old 03-06-2012, 03:02 PM
Bob Kontak's Avatar
The bore at the gear end is 0.482" but that is fighting a chamfer which leaves little of the real bore to grab onto. So you got rough. Best I can do without busting it down.
It appears there may be a step bore in the gear unit as the .482 number I gave you is a little larger than the shaft itself. I can see around the shaft about 1/4" down. Eyeballing the shaft with the calipers I would say shaft is 0.460".
Old 03-07-2012, 12:53 PM
Alps Adventurer
Traveller's Avatar
Thanks Bob. Thats close enough to the 12 mm that I expected.
All the best,
Alex
Old 03-07-2012, 12:57 PM
Alps Adventurer
Traveller's Avatar
ID of the hole that slips over the shaft: Can't tell without removing the gear.
the overall height (gear and flange): 1.075" (plus or minus a few thousandths)
OD of the gear section: 1.013"
OD of the flange section : 0.662"
number of gear teeth: 12
Since another member asked about a 964 Distributor Pinion, here are some measurements of a distributor pinion for a 993 (same dual distributor as the 964).
Pinion ID: 0.474" (12.04 mm)
OD of the gear section: 1.018" (25.86 mm)
OD of the flange section : 0.667" (16.94 mm)
Number of gear teeth: 12
Height of gear section: 0.436" (11.08 mm)
Overall height of gear: ~0.880" (22.35 mm) - hard to measure in place.
Another parameter needed is the drive gear pin location.
All but the OAL match Bob's numbers.
All the best,
Alex
Old 11-02-2013, 07:20 AM
