Hello all,
Took my 911 SC out for a long drive today. Stopped at the lights and ran my hands over the steering wheel in admiration of my wheels ![]() My question is - is this normal?? ![]() Would appreciate your expert views! Can I just say, that I've had a number of minor issues over the last couple of months of my ownership and I can not tell you how invaluable all your advice has been to this newbie 911 amateur pretend mechanic! So, I'm putting my faith in the collective wisdom here again in the hopes for advice! thank you in advance! j
Johann 1986 911 Carrera [SOLD] 1980 911SC [SOLD] 2004 911 |
Same thing happened to me a couple of months ago in my 89 turbo. You need a new bushing in the steering column. After recommendations from members I went with the Mitch Leland kit sold through Pelican. A pretty easy install and you can search for instructions on the install.
Recreational Mechanic
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Easy fix. Same as above.
1989 911 Carrera Cab 25th Anniversary Edition Euro Pre-Muffler, SW Chip There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad" |
Vaccinated and Boosted
Same thing happened to me. Super easy fix with the kit!
Just do it!
2013 911 Turbo S 2025 Lexus TX350, 2024 Honda CRV Hybrid 1930 Cadillac V8, 1991 Ford F250, 2023 Chevy Colorado And some garage space.... |
Fleabit peanut monkey
Believe there is an article on the procedure in the tech info center. You will need a 27mm socket.
1981 911SC Targa |
I've had this symptom as well, bought the bushing with the intent to replace it only to find that the hub worked its way free during a spirited drive
![]() Last edited by mrehrer; 01-12-2013 at 09:11 AM.. Reason: fixing torque value |
Banned
Cars and Cappuccino
Just read the install instructions. So I am clear, the new metal bushing "displaces" the old plastic one by being mashed into place with a mallet? Not judging, just asking for clarity. Thanks.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
RETIRED
Yup....the next thing that goes on the SC is the turn signal stalk. Get a set of relays.
Ask me how I know....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Okay, I have a momo corse steering wheel which I have to remove prior to getting to the bushing. I am assuming I take an allen key to nuts on the covering piece and go from there. I would post a pic but I'm not quite sure how that is actually done.
i dont have a "pictures and albums" link on my User CP. Anyone got any ideas? I've emailed the webmaster for advice!
No. Remove the horn button and disconnect it. That will give you access to the large nut holding the steering wheel to to steering column
Okay! I was clearly not scrolling down!
here it is! ![]() I dont think I can rip the horn pad off as easily as I probably could with the OEM steering!
Johann,
Be sure to disconnect the battery negative terminal unless you enjoy hearing your horn. Be sure your wheels are straight ahead and your steering wheel is centered. Yes, remove the allen head screws to remove the wheel and expose the 27 mm nut. Remove the horn button and reattach the wheel. You will need it to remove the hub. I can get my Craftsman 27 mm long socket into the resulting hole. Do NOT use your steering wheel lock to hold the steering wheel in place as you loosen/tighten the 27 mm nut. In fact, be sure it is DISENGAGED before you start. When you are using your breaker bar to loosn the nut, be sure you are turning it AWAY from the Windshield to avoid having it break the glass. Once you loosen the nut, leave it on when you pull the wheel off. It will pop off and you do not what it to fly off and hit you or your windshield. Be sure you mark the splines so you know where to reinsert it. Feel free to ask anymore questions.
The Horn button actually comes out easier than you think. If you have a small penknife blade you might still be able to pry it gently between the outside of the horn button and the inside of the ring with the allen bolts. Try it as least before you go to the trouble of removing all the bolts
In addition to having the bushing faulty on my car, I also had an issue where the 2 bolts holding the steering column up to the dash had also come loose. Easy fix, but an extra step beyond the bushing.
1985 911 Targa (Black/Black) |
The Horn button is a totally separate assembly from the wheel. I know that for my Momo Horn Button, the back is completely sealed. If you are able to pry the front button off of my button, you will have the solid back of the button assembly in the way. Unlike the stock button, they are NOT integrated into the wheel.
Reiver
Just disconnect the wheel first, takes one minute.
No need to remove the wheel from the hub. Definitely disconnect the battery to avoid playing a game of "Operation" that your neighbors will not enjoy... |
