-   -   911 fuse panel question (http://forums.pelicanparts.com/porsche-911-technical-forum/732349-911-fuse-panel-question.html)
upwardr 02-03-2013 08:08 PM
I'm trying to get some gremlins out of the electrical system and thus rferred to the factory manual.
My 911 is a 1971 and when looking in the manual it shows 2 panels of 8 curcits each. My car has a 10 curciit on top and 8 below total 18 fuses not `16 as per factory manual.
Which is right?
If 16 is correct where can I find the layout for the fuses and colour of wires.
http://forums.pelicanparts.com/uploa...1359950923.jpg
pete3799 02-03-2013 09:37 PM
Can't answer your fuse question but is that battery really laying on its side?
Porboynz 02-03-2013 09:38 PM
That is correct, I have posted the labels I used for my 1972 at this Drop Box link, first time I have tried to do this so tell me if you can download the pdf, or not.
https://dl.dropbox.com/u/97920207/FuseBoxLabels02.pdf
al lkosmal 02-03-2013 09:58 PM
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
10 and 8 is right.
Pelican has the electrical diagrams for the 71 911.
It shows a 10 position and an 8 position.
regards,
al
targa44 02-03-2013 10:06 PM
Here's a jpeg of what I've got on a '73.... s/b? very similar. The color codes match the diagrams I have - but.... PM me if you need more files. I'm currently updating my fuse panel and everything is apart.
http://forums.pelicanparts.com/uploa...1359957764.jpg
upwardr 02-04-2013 05:32 AM
Thanks for the replays, will certainly make things easier to figure out.
Yes the battery is on it's side, it's a dry cell Odyssey.
upwardr 02-04-2013 05:39 AM
Porboynz link worked fine. Download was no problem and very helpful.
irl 02-04-2013 10:28 AM
Nice anybody have an illustration like this for a 74-77 they can post.
Allen_70S 02-05-2013 07:21 AM
Upwardr:
Here is the 70/71 information. A thread about 9 months ago showed where "reproduction": labels for the inside of the fuse covers can be obtained. I'll do a search and see if I can resurrect the information.
Fuse Box #1
1 Amp =5, Interior lamp, clock, luggage space light
2 Amp = 16, Warning light
3 Amp = 25, Windshield wiper, windshield washer
4 Amp = 16, Cigarette lighter, auxiliary heater
5 Amp = 16, Sunshine roof, rear window wiper
6 Amp = 25, Window opener
7 Amp = 25, Fresh air blower
8 Amp = 16, Stop-turn-signal and backup light
9 Amp = 5, Blinker light, front left
10 Amp = 5, Blinker light, front right
Fuse Box #2
1 Amp =8, High beam left
2 Amp = 8, High beam right
3 Amp = 8, Low beam left
4 Amp = 8, Low beam right
5 Amp = 5, Parking light left
6 Amp = 5, Parking light right
7 Amp = 5, License plate light
8 Amp = 16, Fog light
5 Amp = Yellow
8 Amp = White
16 Amp = Red
Al
Allen_70S 02-05-2013 07:35 AM
Upwardr:
I found the thread. Do a search on fuse + labels. the thread "Fuse Box Labels" (including 70/71) is the sixth down on the list - at least it was 10 minutes ago. Good Luck.
Al
targa44 02-05-2013 07:31 PM
upwardr.... your car doesn't have a/c or fog lights?
thanks,
upwardr 02-07-2013 08:50 PM
Allen Thanks, with all ths info I hope to be able to clear up some malfunctioning items.
Targa No, car had AC but was afternarket added later since it was not on the COA. It does not have fogs as per the CoA but the wires are there and I hope to add some though the grill lights.
upwardr 02-07-2013 08:59 PM
fred cook 02-08-2013 05:16 AM
Replacement fuse panels
For those interested, I have a panel for the 69-71 cars now going thru "beta testing". Once a couple of details are worked out, I will be able to provide fuse panels that use the ATO type fuses for the earlier cars. The vertical orientation and panel measurements are what kept me from building one earlier. I have had a number of requests from owners of these years cars and have wanted to be able to address this part of the market.
Allen_70S 02-08-2013 07:45 AM
Larry:
When I copied in the fuse panel data I missed the last line, which defines the 25 amp fuse as being blue in color.
Al
