Machine shop resource?
Has anyone got a machine shop that has machined a standard 1972 oil console to use the oil thermostat for a front cooler?
Plenty of machine shops around, but I'd like to use one that has done this task a few times. |
Have you contacted Engine Machine Service in Inglewood/LAX? Dan or Bill are cool cats, they will tell yeah who can if they can't.
I'll check with them. I've had them do a lot of work for me over the years, but mostly case & heads.
EMS has never done this particular conversion. Anyone know of a shop that has?
Check with Chuck Moreland since it appears he's provided this service before?
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/415125-front-cooler-1972-911t.html#post6575423 Ask docdan how he did it http://forums.pelicanparts.com/porsche-911-technical-forum/678902-72-911t-re-worked-oil-filter-console-questions.html |
TRE did one for me
Elephant can do it and ultrasonic cleaning as well, you don't want any metal bits floating around.
... Eagle: Tim Leedy see more photos by Tim Leedy. Graebener-Reika Inc.'s Hendrik Beer, from left, service manager, and Randy Little, operations manager, work at a tubing machine at the company's new headquarters in Ontelaunee Township. ... "In 2011, we decided to move to a stand-alone facility." All the sales and technical capacities of the business are conducted in Berks County, but some human resources and other services are still performed in Napoleon.
printer ink |
Saw your PM to me this morning...and then came across this post thereafter.
Chuck Moreland of Elephant Racing does this service, and would be a good resource to contact for your particular job. He "walked" me through the entire modification procedure, which iwas a relatively-straightforward job. The machining required is pretty basic...measure the thermostat diameter...open up the inner diameter of the oil console...ultrasonically clean the console to remove all of the metal shavings. I am very sure that any good machinist worth his salt can do this job for you. |
Machine shop
Another would be:
Vellios 4625 Manhattan Beach Blvd, Lawndale CA Tel# 310-643-8540 I've used these guys for decades. Your requirements are very basic. Good luck, Gerry |
| All times are GMT -8. The time now is 10:05 AM. |
