-   -   Time for New Timing Chains? (http://forums.pelicanparts.com/porsche-911-technical-forum/732542-time-new-timing-chains.html)
Smoove1010 02-05-2013 06:22 AM
In the process of getting the chain housings off and need some help evaluating these chains. Engine has 99K miles, 1987 Carrera, doesn't look like it's ever been opened. I'm doing a top-end (http://forums.pelicanparts.com/porsche-911-technical-forum/729856-87-drop-top-drop-n-top-end.html)
What say you all re: the life-span of these timing chains - time for new ones? I'm not sure what fully-extended tensioners look like, so I've no real good frame of reference...
Thanks in advance for any learned opinions,
GKhttp://forums.pelicanparts.com/uploa...1360074003.jpg
john walker's workshop 02-05-2013 06:27 AM
i wouldn't worry about it. looks to be plenty of space between the top of the left arm and the housing and both tensioners are about the same, extension-wise.
Smoove1010 02-05-2013 06:38 AM
Thanks for the quick reply, that's good to know. BTW - your crowbar picture from an earlier post saved me lots of time getting my cams out...
GK
john walker's workshop 02-05-2013 08:26 AM
crowbar?
Smoove1010 02-05-2013 09:11 AM
Well, sort-of. Maybe there's a more Porschey name for it...
http://forums.pelicanparts.com/porsche-911-technical-forum/567072-camshaft-adjustment-flange-stuck.html#post5589337
Regardless, I took it as empowerment to use a little persuasion on something I thought would fall out once the bolts were removed. That o-ring that seals the flange against the housing has a pretty firm fit, and the gasket that seals the flange to the cam tower probably had a little adhesive on it.
kodioneill 02-05-2013 12:41 PM
Ladies slipper.
