-   -   Early Turbo tail questions (http://forums.pelicanparts.com/porsche-911-technical-forum/732547-early-turbo-tail-questions.html)
twaldron 02-05-2013 06:59 AM
Is the bracket in the center for an oil cooler, or what? Is the one on the right for a windshield wiper motor? Anyone with pics of this tail with the appropriate parts installed?http://forums.pelicanparts.com/uploa...1360076325.jpg
http://forums.pelicanparts.com/uploa...1360076341.jpg
Bill Verburg 02-05-2013 07:25 AM
Center was the AC the the wiper was on the right side looking from the bottom
wiper
rear condenser center wiper on right
http://forums.pelicanparts.com/uploa...1360077401.gifhttp://forums.pelicanparts.com/uploa...1360077684.jpg
0
twaldron 02-05-2013 07:27 AM
The cover on this tail never had holes for those large freon lines, so I was assuming that it came off a NON A/C car, no?
It has that bracket on the center support and also two holes drilled in the cover plate near that bracket where something was mounted. I wonder if that directional funnel part you show was on all of these tails?
Bill Verburg 02-05-2013 07:45 AM
All '75-77 930s came w/ AC standard in all markets
twaldron 02-05-2013 08:01 AM
I wonder how they routed the freon hose then...Also, this tail has the smallest second grill which seems too small for a condenser. Did they use the tiny grill for A/C too? Or maybe it's a different year tail?
Bill Verburg 02-05-2013 10:27 AM
The small grill was also for AC but on n/a cars, some race cars may have used it for an oil cooler but that was at the owners direction this is a factory IROC/RSR with small grill
http://forums.pelicanparts.com/uploa...1360088800.jpg
n/a AC is a different setup from the turbo AC
twaldron 02-05-2013 07:52 PM
n/a is North American cars?
How does that plastic fan shroud or funnel attach? Could the center tab in my picture be for mounting that? Has it shown to be beneficial as far as cooling, or are they generally removed to increase airflow?
twaldron 02-05-2013 10:51 PM
Ok, to respond to my own post, in case anyone else wonders in the near future....Looks like the tail is a non A/C tail (due to the shape of the inside panel and lack of freon hose holes). Also, the center bracket is, in fact, to mount that plastic air intake fan shroud (whatever it is named). Here is a thread that pretty much covers it:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/585108-wtb-early-turbo-tail-inner-panel-shroud.html
But one question still stands...how effective and necessary is the plastic shroud?
Bill Verburg 02-06-2013 04:33 AM
n/a is normally aspirated, there were many non AC n/a cars that used the small second grill, the AC cars used a larger second grill
