86 cabriolet 2 post lift points
I need to do the valve guides and went to put my car (86 911 cabriolet) on the lift......looked for a good spot but couldn't find one. The factory seam has a hose running right next to it, at both the front and rear area lift points. I saw some people don't like lifting at the seam in fear of crushing them. Where do you lift it then? I like the custom brackets for the rear someone on here made.
Do I lift it where the hose's are? Will it squish them?
anyone have any pictures?
Old 02-05-2013, 06:44 PM
Here are some pics of my 85 on a two post lift. You have to be really careful in front of the passenger side rear wheel. The oil lines are very close to that spot.
I too want to get some brackets made to put on the feet of the lift at least for the rear. The the rear torsion bar. is just out of reach it's so high in the fender.
Old 02-05-2013, 07:38 PM
Thanks for the pictures! That's were I have them now but with only half the pad on the car I was concerned with it.
Old 02-05-2013, 08:30 PM
