-   -   How do I check headstuds (http://forums.pelicanparts.com/porsche-911-technical-forum/733413-how-do-i-check-headstuds.html)
mr911er 02-10-2013 09:51 AM
Hi
Just bought an SC :) and I am half expecting to have one or more broken headstuds:(. At the moment I am putting together a program for dealing with all the other problems on the car - but I need to know if I have to find 3K to replace the cylinder head studs.
As a complete beginner I have some dumb questions.
I am assuming it is just the lower studs that could be the problem since these are Dilavar on my 1982 model. I have ordered two gaskets for the valve covers which I intend to remove.
I shall drain the oil from the engine first - how much of this is there by the way - I understand there are 9 quarts in the oil tank - but how much is in the engine itself?
Once I get the covers off I assume that if a stud falls on the floor its broken - but what if they dont? How do I inspect them? How can I tell if the studs are cracked rather than broken?
Once again any advice is appreciated from a dumb beginner.....
theFONZ 02-10-2013 09:55 AM
While doing my first valve adjustment on my current 911, I just inspected to see if they were all there then gave them a little twist with a 10mm t-handle.
ETA: Did you order just the gaskets, or the kit that comes with new nuts? You will need new nuts. Also, I'd recommend doing other things while you are in there for the first time like new plugs, and other general tune-up items. Our host sells a "tune up kit" that I've used before.
mr911er 02-10-2013 09:58 AM
Sounds like they were all ok - I am scared that any little twist will cause them to break - I guess if thats the case then they're knackered anyways....
yelcab1 02-10-2013 10:03 AM
if they are healthy, a little twist from you is not going to hurt them.
theFONZ 02-10-2013 10:03 AM
Yeah, I was slightly afraid of breaking one, but thought if I do, oh well... it was going out anyway.
mr911er 02-10-2013 10:13 AM
Thanks guys
How much oil is there comes out the engine?
nettles503 02-10-2013 10:51 AM
Did you read this?
Pelican Technical Article: 911 Valve Adjustment Made Easy
glennspiegler 02-10-2013 01:01 PM
My 3.2 Carrera take 10.75 with filter
James Brown 02-10-2013 01:30 PM
i think he meant in the engine, just drain it or jack it up one side at a time (use jack stands) you get 3-4 quarts out, use a clean container and put it back in after done WYIT, check the valve lash (uh, here we go).
Nick Triesch 02-10-2013 02:39 PM
Why in the heck would you give them a little twist anyway? If they are all there and they feel tight, why not just leave them alone? If it ain't broke....
Ronnie's.930 02-10-2013 03:38 PM
How would you know they feel tight if you don't give them a "little twist"?
SCadaddle 02-10-2013 04:01 PM
IF they are completely broken they will probably fall out. My 82 SC had one broken and 2 that were failing. Interesting enough, as difficult as the studs were to get out of the case using heat, bees wax and the SnapOn collett tool to break the factory loctite's grip, the 2 that were failing did not snap off like I expected them to do.
That being said, if they aren't broken I wouldn't touch them.
http://forums.pelicanparts.com/uploa...1360540656.jpg
theiceman 02-10-2013 04:07 PM
Do NOT give them a little twist. Visually inspect. If they are good leave them. They are relatively speaking low torque anyway.
strikee 02-10-2013 05:21 PM
I think by "giving them a little twist" people mean "apply pressure to see if they turn". You are not trying to shift them, just to see if they spin freely (ie broken). I did this the other day. It was not my intention to turn the head studs, just see if they were broken.
Changing the nuts and gaskets every time you are in there is a waste IMHO. If the gasket looks good and the nuts are in good shape then they should be fine to re-use. Again, did this the other day an no leaks. As I said. IMHO.
Tks
Ed
80-911SC 02-10-2013 08:06 PM
use a magnet .. if they are broken the end will come out .. there are those that say to re torque them but I personally would not try it ...
theFONZ 02-10-2013 10:17 PM
How did you know they were failing?
mr911er 02-11-2013 05:32 AM
Tks
Ed
This was my interpretaion too
mr911er 02-11-2013 05:33 AM
I thought Dilavar was non-magnetic?
Originally Posted by thefonz (Post 7266253)
how did you know they were failing?
+1
SCadaddle 02-11-2013 09:20 AM
Originally Posted by mr911er (Post 7266544)
+1
How did I know they were failing?
Simply because due to the one broken stud that fell out when we removed the lower left valve cover, and noting the regular hex head nut on the stud adjacent to that one....which made perfectly good sense seeing as how we found the starter attached to the transmission with not one but two barrel nuts, and furthermore intrigued by finding a valve keeper collet next to the screen on the oil sump plate (which we removed to have a look around while changing the oil) I decided to tear the engine down to replace all the dilivar studs. Once you get the cylinders off, it was pretty apparent as per the photos.
In the words of the Late Great Harry Pellow: "I have found the mark of the turkey", and to quote Walter Sobchak "Smokey, my friend, you are entering a world of pain."
SCadaddle 02-11-2013 09:49 AM
The Dilavar studs are non-magnetic. However, the barrel nuts on the end of the stud are quite magnetic, and your pick-up tool is going to contact the nut before the stud.
mpetry 02-11-2013 09:53 AM
When I check them using my Snap On torque wrench, click type, they "ring" a little bit when the wrench clicks indicating proper torque (23-24 ft/lb)
Ping !
If they twist and do not hold torque, they are probably bad :-)
5String43 02-11-2013 09:55 AM
Is your car making the telltale "playing-card-in-bicycle-spokes" noise? If it is not, you might be OK. My car, an '82, was making that noise. The resulting "while-you're-in-there" tab was far north of the $3,000 you mention. Good luck with this. It's way to easy to spend lots of money on these things.
mr911er 02-11-2013 11:14 PM
I havent noticed the sound, so I am hoping they are ok - but need to know for peace of mind and to prioritise what to do with the car. If they're ok I can put it off for a few years...
btw UK here, so I was thinking £ - even so probably more....
theFONZ 02-12-2013 05:29 AM
<!-- BEGIN TEMPLATE: bbcode_quote -->
<div class="pre-quote">
Quote de <strong>mr911er</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">+1</div>
</div>
<!-- END TEMPLATE: bbcode_quote -->How did I know they were failing?<br>
<br>
Simply because due to the one broken stud that fell out when we removed the lower left valve cover, and noting the regular hex head nut on the stud adjacent to that one....which made perfectly good sense seeing as how we found the starter attached to the transmission with not one but two barrel nuts, and furthermore intrigued by finding a valve keeper collet next to the screen on the oil sump plate (which we removed to have a look around while changing the oil) I decided to tear the engine down to replace all the dilivar studs. Once you get the cylinders off, it was pretty apparent as per the photos.<br>
<br>
Ahhh, that makes sense. For some reason I was under the impression you knew those were failing before removal.
Thanks!
rs6er 02-14-2013 07:00 AM
When I went to try my first valve adjustment, I discovered 7!!! broken studs. Previously did not hear bicycle spoke sound and car ran— not as well as after the rebuild by Dan Jacobs though.
suprxman 04-02-2013 02:50 PM
anyone else find 12 broken studs?
rs6er
7 broken dilivar studs arent too bad. I just found all 12 of the dilivar studs on my 80 sc were broken.
Is this rare?
theiceman 04-02-2013 03:27 PM
wow all 12 ? did you have performance issues or just get the car ? I cant belive you could drive that thing without noticing having 12 broken studs. i would be worried about corrosive exhaust gasses escaping betwen the cylinder and head and doing serious damage ..
