-   -   setting clutch help....PLEASE!!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/733462-setting-clutch-help-please.html)
wholio94112 02-10-2013 12:53 PM
...pretty certain i got the engine and tranny mated well, and i am just about done with complete re-install of motor of 1986 930, when i realize the one picture i didnt get was of the clutch down below before i release the tension...also, my clutch pedal is on the floorboard, springing back down when i pull it up...have done everything according to waynes books, tech forums, etc, and would really appreciate help...thanks...
James Brown 02-10-2013 01:00 PM
no problem, just follow the instructions on clutch cable replacement in the tech articles or your repair manual.
DRACO A5OG 02-10-2013 03:31 PM
Remember it is two stage process:
1. gap at the clutch arm with out cable is 1.20MM, with cable and tensioned it needs to be reduced to 1.00MM, have a helper keep the pedal up after you install the cable to the clutch helper arm.
2. the difference between pressed and unpressed clutch pedal must be 25.0MM +/- 0.5MM, this is adjusted at the floor board stop ( that metal plates with two allen bolts and a rubber cushion. You defnitely need a helper here as you sound off the readings below.
That is it, clutch should release and engage half way on the pedal throw.
Jim
wholio94112 02-10-2013 06:40 PM
thanks guys, just had a helluva time prying the omega spring into place...now waiting on a helper for the adjustment...cheers!!!
DRACO A5OG 02-10-2013 09:21 PM
Just use a BFS and pop it over.
When you remove and install the cable you will push it over to make it easier, a hint :D
