Rear wheel Play
Last week end,I was doing some maintenance on my SC. I had the rear of the car in the air & noticed a 1/4 " of play in the right rear wheel. I just replaced the bearings,bushings,shocks,& t-bars. Should the wheel have any play ? I can move the wheel top to bottom about a 1/4 of an inch,the u-joint moves in conjunction with the wheel. Is this normal, or did I screw up ? when the e-brake is applied or when the car is in gear there is no play. Thanks for any imput. Craig
80SC
Old 07-02-2002, 06:51 PM
one of gods prototypes
bell's Avatar
it sounds like the axle wasn't all the way in the hub after the nut was tourqued.
if it doesn't move when the brake/ebrake is applied it alsmost always means wheel bearing.
can someone second this?
Brought to you by Carl's Jr.
Old 07-02-2002, 08:11 PM
cary's Avatar
Should be NONE............... Make sure the brake drum is seating right.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 07-02-2002, 09:09 PM
Thanks for the information ! I'll pull the drum this weekend & check it out. Craig
80SC
Old 07-03-2002, 08:44 AM
