Always Be Fixing Cars
What adhesive to adhere vapor barrier to inside of door?
I'm doing some internal door work and will need to replace my vapor barrier. I've bought a new one from PP but don't know what adhesive to use to attach it. Anyone done this before?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 04-09-2013, 08:12 PM
I just put them in my 1980 SC when I upgraded my speakers. I don't know if I used the correct stuff or not. I used 3M spray adhesive. It's holds well but you can peel the vapor barrier off if you need to.
Dave
1980 911SC Targa
1990 S2 Cabrio (sold)
2004 C4S (sold)
2006 Boxster (sold)
Old 04-10-2013, 04:16 AM
brock911's Avatar
I just re-upholstered my door panels and replaced the vapor barrier as well, I also used the 3M spray adhesive and it worked fine. Allows for some re-positioning if needed and held the barrier nicely.
Mike
Old 04-10-2013, 04:25 AM
wayner's Avatar
I use a caulking that goes by brand name such as Accustik, or Accustiseal.
It is the same stuff that building supply places (maybe home depot) sell for sealing vapour barriers inside walls.
It comes in black or silver and remains soft.
Run a bead along the surface of the metal, then press the plastic vapour barrier along the bead.
SOLD - 914 wide body hot rod
Old 04-10-2013, 04:27 AM
nineball's Avatar
butyl rope is what is commonly used due the ability to stick very well yet still be removed later down the road. unfortunately the same can't be said for the 3m spray.
Product Prices | Sound Deadener Showdown
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 04-10-2013, 07:38 AM
Darn it! I have some of that and never thought to use it. I don't anticipate removing the panels any time soon - I hope.
Dave
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 04-10-2013, 07:46 AM
Something like this? Dicor BT18341 1/8" x 3/4" x 40' Butyl Tape : Amazon.com : Automotive
So just to be clear - that stuff is tacky enough to hold the vapor barrier in place? I suppose it gets help from the door panel itself.
Old 04-10-2013, 12:43 PM
wayner's Avatar
Why not just use the stuff that was designed for that purpose?
THere are many brands and colours. Here is one
ACOUSTICAL SEALANT
Here is how they do houses:
Vapor Barrier Installation Is The Key To A Tight, Energy-Efficient House
Old 04-10-2013, 01:30 PM
nineball's Avatar
that looks like it will work, only thing that concerns me is that it is only 1/8" thick, but then again it will only be holding up a thin plastic sheet.
Old 04-10-2013, 01:52 PM
