-   -   Trailing Arm / Bushing Options - (http://forums.pelicanparts.com/porsche-911-technical-forum/733690-trailing-arm-bushing-options.html)
Craig_D 02-18-2013 07:04 AM
Originally Posted by GotaT (Post 7280606)
Spring Plates: One of you guys posted earlier about using factory adjustable spring plates. Im pretty sure mine are already height adjustable. So what are the advantages/differences between the factory and other adjustable spring plates - ER, Weltmister, Sway A Way etc?
ER spring plates are much quicker/easier to adjust than the stock SC eccentric bolts, and have the advantage over Sway A Way in that the two plates are secured with a retaining nut. No slap or chance to loosen up, once that is tightened down.
GotaT 02-18-2013 07:52 AM
ER compared to Weltmeister for daily driver use?
Do the aftermarket adjustable plates allow more travel then the OE adj., or just Ease of use?
Any pic of a NON adj OE spring plate comp to ADJ?
GotaT 02-18-2013 07:58 AM
Adjustable - has additional bolts near the torsion bars (forward)
http://forums.pelicanparts.com/uploa...1361202995.jpg
Non Adjustable- No forward bolts
http://forums.pelicanparts.com/uploa...1361203125.jpg
Found it
Craig_D 02-18-2013 08:27 AM
And then there's the Elephant Racing adjustable:
http://forums.pelicanparts.com/uploa...1361204827.jpg
