mangled tube on heat exchanger
The PO of my had new stainless heat exchangers put about 2.5 years and 3000 miles ago. The paper/aluminum hose on the driver's side won't stay on. I took a look and found that the tube is mangled. You can see where somebody tried to crimp the metal.
The problem is that the tube isn't really cylindrical. It's got a bit of a cone shape. I can fit the hose over it but as I tighten the clamp, because of the cone shape, it just slides back off.
Shouldn't there be a metal elbow on the heat exchanger? There's one on the passenger side.
Dave
1980 911SC Targa
1990 S2 Cabrio (sold)
2004 C4S (sold)
2006 Boxster (sold)
Old 02-12-2013, 04:59 PM
Send a message via Skype™ to Porboynz
I think I would be trying to straighten that crimped metal and then sliding a short length of stainless exhaust tube into the heat exchanger thats long enough for the hose clip to attach firmly. The stainless pipe to be a force fit into the heat exchanger.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 02-12-2013, 09:12 PM
That doesnt get flex hose, there is a 90 degree L that goes on to the heat box that the hose clamps to.
Bruce
Old 02-13-2013, 05:14 AM
Thanks guys. I guess the mechanic that installed it mashed it down to get the flex hose on to it. The PO paid $600 for each heat exchanger plus installation - OUCH. I'll order an elbow and see if I can straighten it out without making it worse.
Dave
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 02-13-2013, 05:18 AM
cycling has-been
bkreigsr's Avatar
looks like one of those 'muffler expanders' from the parts store would return it to a point where it would workable again.
Old 02-13-2013, 06:18 AM
Go-Kart Mozart
JAR0023's Avatar
Ouch. That kind of butchery ought to generate an a$$ chewing. On the bright side, you don't have to have a perfect seal on the heat exchangers like you would a fuel or oil line. A small 6" crescent wrench with the jaws closed down will work well to allow you to reform the opening. -J
Old 02-13-2013, 06:54 AM
