HI-Torque Starter IMI 101 VS 101-N
Does anyone know whether the IMI 101 will work on the early 911s, like the one our host sells which is the 101-N. The 101-N just has a little bit more power but the 101 is much cheaper in price. Any feedback is appericated. Thanks!
Anthony
'71 911E w/ MFI
Old 03-04-2012, 09:25 AM
Taking it apart is easy
Jerome74911S's Avatar
Why don't you just ask PP?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 03-04-2012, 10:10 AM
Url Url is offline
Url's Avatar
Reusing an old thread ...
I am about to order the IMI 101 but was wondering if I shouldn't buy a 101-N instead? 101 is localy available, 101-N not sure ...
I'm not sure if I need the 1,5Hp starter (101-N) or if the 0,9Hp (101) is sufficient. I suppose both of them are more powerful than the original one ...
My only reason to replace the starter is to solve my hot start issues.
Thanks!
Old 02-12-2013, 07:46 AM
Racer
winders's Avatar
My high compression 3.6L race engine starts up just fine with the plain IMI 101.
Scott
Old 02-12-2013, 08:06 AM
ASE Master Tech - 35 yrs
larrym's Avatar
this was discussed awhile back (see link below)
- I talked to IMI about the variants - the 101-N is the one you want, made specifically to fit ALL Porsches for which it carries applicability in the parts book
a lower compression (7.5-8.5:1) early engine would not require 1.5 HP
other folks have had mixed results with the alternatives, sometimes finding "spacing" issues
Lots of valuable info with additional links here:
starter ring failure twice in 3 weeks. HELP!!
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-12-2013, 09:13 AM
Racer
winders's Avatar
The 101 and 101-N both fit Porsches the same.
My race engine is over 12:1 compression and the plain 101 turns the engine over fine.
I am not saying one should not buy the 101-N. I am saying the 101 is a reasonable option.
Scott
Old 02-12-2013, 10:03 AM
