Rev limit
Hi all,
Can anyone advise how I raise or lower the rev limiter on a 2.7 motor. The motor has been modified to allow it it to spin up to 7800rpm however limiter kicks in at 6500. Thanks in advance Michael |
depending on dizzy you are using, either use a different rotor or beter to do is get the dizzy properly re curved to the engine set up you have now...
I live for 911 tweaks... |
ASE Master Tech - 35 yrs
buy a new higher limit rotor
mine is 7200 or get a rotor with no limiter - awhile back Henry posted a statement that there is a no-limit rotor available Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net when you get the part number & sorce, please report it back here! .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Ok thanks guys
Michael |
You can disable the existing rotor so it no longer functions to control revs. Just stare at it for a minute and it will become obvious how.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
