aftermath's Avatar
How do I remove this? Fan housing center of trunk.
Car is a 82 930. I need to pull this out of the way for now. Im not sure how to get it out and I have been staring at it for a while. I took a bunch of clips off hoping it would pop in half but that's not the solution. Sorry I don't even know what its called or I would have searched more.
theamsoilguy@hotmail.com
Old 02-15-2013, 03:47 PM
Remove the exterior grille at the base of the cowl, below the windshield. Unscrew the 2 screws that are exposed by the removal of the grille.
JR
Old 02-15-2013, 03:55 PM
Dial 911
A horse with no name's Avatar
Hi...I may be able to help you...What are you trying to do? - Get at?... Windshield wipers?
Cheers
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 02-15-2013, 03:58 PM
howard freeman's Avatar
JR
And be careful with the drain hose on the bottom. The originals are N.L.A.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 319,016 miles now Sons daily driver
08 X5 4.8 156,615 miles
Old 02-15-2013, 03:59 PM
aftermath's Avatar
Cheers
The cars wiring is hacked up bad from a alarm\remote starter install done by someone who had no business doing the work. The car also has a small block conversion ( that I did ). I decided to pull all the heat\ac stuff to simplify the wiring nightmare in front of me. The car isn't ready for heat\ac anyways.
It took me many hours to separate the alarm\starter harness from the car ( still not done ) and in order to properly repair the stock harness Im going to remove it to repair on my workbench, Im giving up soldering laying on my back.
Old 02-15-2013, 04:03 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Like you, I repaired in place, not fun but quite the bear to remove the entire harness. If you care about originality, I found 3M black hockey stick tape almost a perfect match to the original tape on the harness. Good luck on your job.
Old 02-16-2013, 05:29 AM
SCadaddle's Avatar
Howard
And the solution to that if you do manage to ruin the drain tube is a large piece of heat shrink tubing cut to proper length and clamped to the outlet of the blower box.
Toofus.
Old 02-16-2013, 08:54 AM
