Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Dkennel's Avatar
A/C compressor mount removal
Replaced my a/c belt today....it was a pain to remove/loosen the front right mounting bolt, pretty tight space, I wonder if a L-shaped or half moon 13mm wrench would work better here?
Something like this 13mm Injection Pump Wrench Tool VW Audi Mercedes | eBay
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 02-15-2013, 10:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
kuehl's Avatar
Tools, tools and more tools, we can never have enough tools!
We usually use a RATCHETING COMBINATION WRENCH.
You can get them in various flavors. Maybe our host
here has some in their tool section. But... if you borrow
one, don't forget to clean it and put it back in the
right draw.
Old 02-16-2013, 05:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Go-Kart Mozart
JAR0023's Avatar
First post nails it. You have three other bolts/nut holding that plate down. Plus a tension bolt. A stubby gear wrench will get that bolt tight enough. Some folks leave it out altogether. -j
Old 02-16-2013, 05:17 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
kuehl's Avatar
What did we win !!!
Old 02-16-2013, 05:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
I hardly think twice about making a special tool - out come the torch and/or grinder. L-shaped, Z-shaped, reduced OD combination wrenches along with shortened combination wrenches (custom stubbies) for compressor suction and discharge line fittings now populate my tool drawers.
Old 02-16-2013, 07:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
db_cooper's Avatar
A very helpful tool from Snap-On. Long offset 13mm box end wrench. Very handy with the A/C compressor and those hard to get to heat exchanger nuts. Part number S8704
Old 02-16-2013, 08:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
