my timing changed!!
my 76 911s, started running poorly today, so i checked the timing and it's off, the dwell is at approx 40 (38 -+ 3 is acceptable), and i can't rotate the distributor enough to get the timing correct! anyone have any suggestions, fwiw, it's incredibly hot here (NY) the last few days, thanx in advance, andrew
Re: my timing changed!!
as the points rubbing block wears, due to no grease on the cam, the points close up, which results in the dwell increasing, and the timing retarding. so adjust the points.
i'll regap the points, but i did that 2 weeks ago and i was able to get the correct timing for the 911, and it's changed, any reasons? thanx again, andrew
See J Walker's post above; no Bosch grease on cam. Other possibility is that the movable half of the points wasn't tight enough and gradually changed over two weeks.
Check for cracks or tracking marks inside cap or rotor. But since the 40 deg is still within spec (38 + /- 3)... check to see position of rotor at TDC number 1. It should be at the mark on side edge of distributor. If not, reset distributor at Z1 TDC number 1 cyl and go from there... good luck |
anc
It has been my experience that for some reason, the fiber block on new Bosch points wears at an incredibly fast rate. I use Bosch distributor cam grease and have found that in as little as 600 miles, a new set of points will close up due to wear on the fiber block, resulting in retarded timing and a lower idle speed. After a subsequent point adjustment at the 500-600 mile mark, the fiber block seems to wear less, and the points stay where they should for several thousand miles. Good luck. |
| All times are GMT -8. The time now is 06:36 PM. |
