Recently there was an article in 911 & Porsche World which suggested that one should warm the engine through before driving off in a 3.2L
The owners manual suggests that you should not do this! I'm confused. With the 3.2L engine's reputation for eating valve guides, I'm also concerned. Which policy should I follow?
Alan Brown 86 Carrera 3.2 |
Follow the owners manual.
Keep the RPM's below 3000 until the oil temp. reaches the 1st notch on the guage. |
Beware the urban myths!
The owners manual is right. Around a minute of idling at most, then keep the revs below 3 - 4K until you see 180 on the oil temp gauge. NEVER lug the engine [low revs/high load] - always a glden rule but especially when cold. The valve guides? Mine were in great shape at 150,000 miles. High oil consumption can be symptomatic of several issues, only one of which is valve guides. There was a bad valve guide materials choice during the 3.2 production run, but most of these failed before 50,000 miles. Drive it hard, change the oil regularly, and enjoy the ride!
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
I get into my car, start it, and drive away. I keep revs under 3500 and above 2000 (the manual indicates to not "lug" the motor). I don't warm it up for a minute.
Mark Szabo 1986 911 Targa 3.2 (I will miss you) 1985 Scirocco 8V (I will not miss you) 1986 Dodge B150 Ram Van (I can't believe I got $200 for you) 1987 Escort 5-speed 1.9 RIP |
Follow the instructions above. One things people forget when they let their cars warm up in their drive way, is that the transmission oil is still cold.
Neil '73 911S targa |
i struggle with this one. my head tells me to warm up first, but i go with the manual........ditto above, just drive carefully for ten mins.
Rich ![]() '86 coupe "there you are" |
Forgive me for agreeing with 911 & Porsche World, but if you don't let the Carrera go through the warm-up ritual (fast-idle) governed by the DME, it has a tendency to sort of choke and want to stall at low RPMs, forcing you to give it more gas and inevitably pushing it over 3000 (which seems to clear-up the problem). I've been told this is a characteristic common to all 911s and a mechanism built into the design. Shifting is also much harder, particularly with the 915, when you drive off cold. I've tried both methods, and a reasonable warm-up period seems a lot easier on the car. Ok, now you guys can blast me
I let my 85 run for about 30 secs to get the oil circulated and under pressure and then drive off...no prob keeping revs at 3K or less until warmed up. Shifts a little more tightly for a few blocks but thats fine.
64 356C Cabriolet 85 Carrera Coupe...Walker-maintained...Wong-chipped 02 Yukon XL 2500 82 Vespa P200E 186,000 MPS.....not just a good idea....its the Law! "Too much of everything is just enough" |
Senior Member
By the time you get the seat belt fastened and get situated in the car after starting it, its ready to roll. No reason to sit longer and waste fuel, you started the car to go somewhere.
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
