| Delta Venture |
02-16-2013 09:57 PM |
1972 911 No Spark Problem
Hello,
I have a 1972 Porsche 911 that's been sitting for a few years and I'm trying to get it back on the road. I changed major fluids and installed some rebuilt Webers. When I went to start the car I had no spark, no headlights, no turn signals (all fuses are good) even though it was running fine when I stopped driving it. The battery is new, a test light attached on the body ground strap and the probe to the battery ground does not light up the probe so I don't think there's a open circuit or short. The MSD 6AL box and MSD Blaster II coil are both good as I can get a spark if I use a test lamp with the clamp on rear fuse box (top fuse) and the probe touching the middle fuse on same block. With the key off and coil center wire with a spark plug attached and close to ground the spark shows every time I touch the probe to the center fuse end. However, I have no spark if I turn the ignition key to run (with the center coil wire attached to a spark plug close to ground) or when I remove the white MSD points wire and tap to ground (should spark every time I tap to ground). I don't know if I'm bypassing the ignition run position by connecting the test light and getting a spark, but my only thought is a bad ignition switch? Any thought before I start changing out relays, switches etc.?
