-   -   If pulling on wiper stalk triggers the wipers... (http://forums.pelicanparts.com/porsche-911-technical-forum/734896-if-pulling-wiper-stalk-triggers-wipers.html)
wrinkledpants 02-19-2013 05:55 AM
then would that rule out the wiper stalk for a non-op washer system? Haven't really dug into the issue yet, but looking back through the receipts, the wiper stalk switch was replaced in the last 20k miles. I can't hear the washer pump engage when I pull on the switch, so I'm thinking the motor may have died.
redstrosekNic 02-19-2013 06:13 AM
Check for power at the motor while a helper pulls the stalk.
spuggy 02-19-2013 10:58 AM
^^^ This....
Josh D 02-19-2013 11:19 AM
A lot of time the the little brass pump gears get gummed up with dry fluid. The pump can be disassembled, cleaned, and lubed easily.
kidrock 02-19-2013 04:39 PM
are you sure the nozzles aren't clogged?
wrinkledpants 02-19-2013 06:27 PM
I'd hear the pump running if they were. But, I don't hear the pump running.
kidrock 02-20-2013 08:23 AM
I don't hear my pump, and it works fine.
wrinkledpants 02-20-2013 09:09 AM
OK. I'll start with that, then. And if that doesn't help, check for power at the pump, and then disassemble if needed. As a last resort, buy another pump. They seem pretty cheap.
chockymonster 02-20-2013 09:36 AM
Is there water in the bottle?
I know it's a silly question but it never hurts to ask!
wrinkledpants 02-20-2013 09:38 AM
Yeah - I put a gallon in :)
wrinkledpants 02-22-2013 10:44 AM
Just an update, looks like it was gummed up. I could barely hear it when I put my ear to it and my fiancé pulled the wiper stalk. I reversed the connectors to reverse the pump to try to break it free. It worked. I then blew through the pressure side of the hose and had free flowing air, but only the drive side head was working. Pulled the check valve off the passenger side and it was froze shut. Got that unstuck and cycled it a few times with some spit and my breath, and it worked smoothly after that.
Thanks for the tips!
Josh D 02-22-2013 10:57 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/731466-ac-install-10.html#post7278216
Second time this week. I'm on a roll!!
