SLR SLR is offline
SLR
Brocken Fushe.
One of the spokes is cracked all the way through on a 15" Fushe wheel.
Can it be welded ?
Thanks Steve
Old 07-05-2002, 12:28 AM
critter's Avatar
One of my fuchs was cracked about 3/4's thru the spoke and I had it welded by my brother in law who builds high dollar alum boats.It was a bit of work grinding down the weld to make that spoke look exactly the same as the others.I would recomend a high speed air die grinder and a assortment of paper grinding discs and scotchbrite pads from course to fine.I gave it a shot with a rattle can and it looks good as new. Good luck
Grant 75 911s targa
1991 Dodge Cummins turbo diesel 3/4 ton 4x4 ( stump puller)
Old 07-05-2002, 05:42 AM
Senior Member
SLR,
Fuch's wheels are EXTREMELY tough and I have never seen a cracked one. Seen lots of them that were bent like a pretzel after an accident but still one piece and even holding air. First question is, are you positive that its a real Fuch and not a replica?
Second question is what in the world has happened to the wheel to stress it to this point and are you sure you want to trust your life to this wheel anymore??? If its a actual defective wheel that has not been in an accident, please take it to the dealer and get them to send it back for testing. Fuchs would probably give you a new one.
My bet is that sometime in a past life the car or wheel (on another car) was in a massive accident or shunt. Additionally, if you do have it welded, take it to a good shop and have it crack checked to confirm that there are no other areas that are cracked and just not showing yet.
Joe
Old 07-05-2002, 07:03 AM
Automotive Writer/DP
Randy W's Avatar
I have seen a real 8x15 Fuchs develop a crack after being used on the rear of a coil-over 911 for thousands track days miles. So I think it is possible to get a cracked Fuchs without a major hit. I think it is a good idea to retire the wheel rather than weld it however, if any track days are contemplated.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 07-05-2002, 08:45 AM
I had a cracked Fuchs that had been used only on a street car, but it had been chromed by the previous owner and I understand that can make the wheel brittle.
Old 07-05-2002, 09:50 AM
Senior Member
Superman's Avatar
I think it is odd for a Fuch to develop a crack, and I'd agree with Randy again. I wouldn't trust a cracked Fuch, even one that has been welded. Besides the question weld difficulty and quality, one has to wonder what (if a Fuch has developed a crack) is wrong.
Mocha 1978 911SC. "Coco"
Old 07-05-2002, 10:04 AM
pwd72s's Avatar
When budgeting for wheels or tires, one should factor in how much the lives of those riding on them is worth. Count me among those who would junk the wheel...they make good hose hangers, I understand...
Old 07-05-2002, 10:10 AM
Senior Member
Paul,
A wheel like this makes a very nice table, put some glass on top and you get to enjoy the wheel in a safe manner for years!
Joe
Old 07-05-2002, 10:13 AM
SLR SLR is offline
SLR
brocken fuchs
Well sorry about the misspelling on the wheel ( Fuchs) !
thank you all for the input and I will replace the wheel. I have the opportunity to buy a set of 16” wheels and I think that's what I will do.
Thanks Steve
Old 07-05-2002, 10:51 AM
