Phot's of the cluth kit
Steve when you remove your existing clutch and pressure plate just set
the old pressure plate on your work bench and remove the throw out bearing one pc at a time and put the new one together just as the old one was. It will be clear as mud as to the order they go together when you see it. Thanks Mike |
That makes good sense.
| All times are GMT -8. The time now is 08:21 AM. |
