fan worn?
I recently sold a fan which I acquired with some parts I bought here on the site. I sold the fan to a gentleman in Australia, who is having some trouble with slippage. Seeing the fan made it halfway around the world in 1 piece, we are both disappointed to see this. He tells me the mounting area is worn, can someone identify from these pics where the problem may lie? I have compared his fan to another which I have and cant see any difference. Where does the problem lie/are there maybe different pully assemblys? From what I can gather, the pully is spinning on the fan housing when tightened up. thanks Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
backside of fan
The pics you posted do not show the worn area. Look where the outer pulley half would mate to the fan hub, and you'll see how it no longer has distinct corners... they are all rounded, causing the slippage.
Dustin |
Dustin |
They are worn over time from not having enough shims on the pulley. Must have a min of 6 shims.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Sounds like he didn't put the key on the shaft with the fan causing it to spin!!
^^^^^ is exactly what I was wondering.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
The problem with the fan in question is not the keyway.
Howard
I can't tell from the photo...
Doyle
Ken 1986 930 2016 R1200RS |
