-   -   3.6L O2 Sensor - on or off? (http://forums.pelicanparts.com/porsche-911-technical-forum/73558-3-6l-o2-sensor-off.html)
widebody911 07-04-2002 02:55 PM
I see that some people disconnect the O2 sensor on their engines, even the 3.6Ls - why? What are the benefits/drawbacks?
FWIW, mine is connected.
Tinker 07-04-2002 11:31 PM
I don`t know why anyone woukd unhook it. Mine is also hooked up. W/O your system would go into and open loop with a default setting at idle and part load. At WOT it dumps so much fuel that the O2 sensor is not a factor.
Tinker
WydRyd 07-05-2002 05:01 AM
The O2 sensor on my 3.2 Carrera (turbo) is also disconnected.
This makes the A/F ratio richer as the O2 sensor (when connected) forces the Motronics to run in the 13.x:1 A/F range. A bit too lean for a turbo application.
Hope that helps FWIW...
911pcars 07-05-2002 10:34 AM
If you must disconnect it for some reason, why not just connect a switch in the sensor signal wire so you can control when it operates? During part throttle operation a rich mixture can potentially dilute the oiling system, foul the plugs and decrease fuel mileage.
Sherwood Lee
http://members.rennlist.org/911pcars
