fan worn?
I recently sold a fan which I acquired with some parts I bought here on the site. I sold the fan to a gentleman in Australia, who is having some trouble with slippage. Seeing the fan made it halfway around the world in 1 piece, we are both disappointed to see this. He tells me the mounting area is worn, can someone identify from these pics where the problem may lie? I have compared his fan to another which I have and cant see any difference. Where does the problem lie/are there maybe different pully assemblys? From what I can gather, the pully is spinning on the fan housing when tightened up. thanks Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 02-22-2013, 05:33 PM
backside of fan
Old 02-22-2013, 05:35 PM
redstrosekNic's Avatar
The pics you posted do not show the worn area. Look where the outer pulley half would mate to the fan hub, and you'll see how it no longer has distinct corners... they are all rounded, causing the slippage.
Dustin
Old 02-22-2013, 05:43 PM
Is this fan useable?
Dustin
Old 02-22-2013, 05:44 PM
howard freeman's Avatar
They are worn over time from not having enough shims on the pulley. Must have a min of 6 shims.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 02-22-2013, 07:44 PM
Sounds like he didn't put the key on the shaft with the fan causing it to spin!!
Old 02-23-2013, 03:36 PM
dshepp806's Avatar
^^^^^ is exactly what I was wondering.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-23-2013, 04:47 PM
The problem with the fan in question is not the keyway.
Howard
Howard Freeman
Old 02-23-2013, 06:09 PM
pa911's Avatar
Originally Posted by redstrosekNic View Post
The hub is grooved out as the photo in the above link shows.
Old 02-23-2013, 06:23 PM
dshepp806's Avatar
I can't tell from the photo...
Doyle
Middle Georgia
Old 02-23-2013, 06:57 PM
Change your Darn Fan Belt Regularly or Suffer Like Me!
Reasons for pulley spinning on fan
Ken
1986 930 2016 R1200RS
Old 02-23-2013, 07:46 PM
