Author of "101 Projects"
Here we have a photo of the completed short block. Use the chain sprockets to help keep the chain hanging freely as you turn the engine. Also note the use of JB Weld to replace the original factory bonding agent that was removed during the cleaning process.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
JB Weld?
Matt Holcomb MFIWDP 1974 911 Carrera 2.7 RoW 1975 Mercedes-Benz 280SE Dedicated Homepage Engine Rebuild Homepage Porsche Owners Gallery Profile Pelican Gallery Profile |
Warren Hall Student
JB Weld is an epoxy type of glue that has particles in it so you can use it to fill as well as glue and even drill into it if need be.
They sell it in automotive stores over here. Bobby |
Despite it's rep as a MM cure-all, JB Weld is perfect for this particular application...
-Wayne
How does it compare to Loctite or that Japanese stuff? Is it stronger?
It just works really well for sealing these plugs - not too familiar with the Loctite equivalent, or the 'Japanese' stuff...
-Wayne
