-   -   ER Offset Camber Plate Question ????? (http://forums.pelicanparts.com/porsche-911-technical-forum/735800-er-offset-camber-plate-question.html)
Devil Dog Mosport 02-24-2013 09:03 AM
Okay.. just to confirm "what I think is correct"...
Which one is Left and which one is Right? From Pilot's seat
Thanks , anyone?http://forums.pelicanparts.com/uploa...1361725391.jpg
James Brown 02-24-2013 12:55 PM
in the picture they are backwards, flip them around.
Devil Dog Mosport 02-24-2013 12:59 PM
ah okay... so the bolt holes are closer to the mount on one side and they go inboard to center of car?
proffighter 02-24-2013 01:30 PM
Here is how to mount. This way you get more camber (if desired) easier. Maybe no need for, but mount it this way anyway
http://forums.pelicanparts.com/uploa...1361741406.jpg
James Brown 02-24-2013 01:34 PM
correct, the idea is to angle the wheels inboard (at the top) to increase camber - make sense?
Devil Dog Mosport 02-24-2013 01:58 PM
Now it does.. thank you sir
Devil Dog Mosport 02-26-2013 04:08 AM
just an update on the placement for future reference and straight from "the man"...
If you want more negative camber, arrange such that the bolt holes are towards the outside. Less negative camber, arrange such that the bolt holes are towards the inside.
proffighter 02-26-2013 04:40 AM
Sorry, but who wants less than stock camber??? Thats what yo get if switched...
Devil Dog Mosport 02-26-2013 04:42 AM
Pure Racing applications, depending on the track...depending on your driving tactics, your line, and your tires... temp, track conditions.. I could go on..
proffighter 02-26-2013 04:57 AM
What racing application asks for positive camber? Stock is
Devil Dog Mosport 02-26-2013 05:43 AM
Clearly you're confused .... If you want more negative camber Positive camber has not entered this conversation..
But, you're right... touche' .. One typically would not want positive camber in the application..
Alex973 02-27-2013 12:58 PM
unless NASCAR?
Devil Dog Mosport 02-27-2013 01:05 PM
Originally Posted by Alex973 (Post 7299486)
unless NASCAR?
Only if you want to eat the wall at 185mph!
Alex973 02-27-2013 01:13 PM
camber plates
Folks I just bought these from here these do not look
like what you see above can anyone comment chime in please
i do not see any bearings it is just bushings with a 901341018http://forums.pelicanparts.com/uploa...1361999601.jpg
http://forums.pelicanparts.com/uploa...1361999616.jpg
Devil Dog Mosport 02-27-2013 01:16 PM
These are just camber plates with OEM style rubber bushings.. Stock. What were you expecting? How much did you pay?
James Brown 02-27-2013 01:19 PM
them stock, the fancy red ones will cost a bit more
