I am just saying that on an 83sc the only black plug goes to the frequency valve, Bosch 0 280 150 300! Its below the throttle body along the fuel lines!
http://forums.pelicanparts.com/uploa...1361839451.jpg |
Here it is mounted to the back of the throttle body!
http://forums.pelicanparts.com/uploa...1361839759.jpg |
78/79 SC doesnt have a frequency valve, thats part of the oxygen sensor system
Bruce |
Ok, the black plug goes on the AAR! I took pictures and as I said, on a 78 SC all plugs are color coded with their respective receivers so dummies like me don't mix them up (which I did do a year or so ago).. I'm amazed that they changed the color coding from 78 to 79 (as Sonnet's photo showed).. I like that they match!
Here they all are - AAR Plug - Black http://forums.pelicanparts.com/uploa...1361842344.jpg WUR Plug - Grey http://forums.pelicanparts.com/uploa...1361842377.jpg Throttle Plate - Blue-Green (Flash makes it look like CSV color but it is darker) http://forums.pelicanparts.com/uploa...1361842405.jpg CSV Plug - Blue http://forums.pelicanparts.com/uploa...1361842442.jpg |
Color of male and female connectors the same, what a great idea!
Those Germans.... :) Wouldn't work on my car any more as the wur connector was broken and the only replacements available are black... Glad you found where it goes. Hope it doesn't affect your idle and mixture too much... |
| All times are GMT -8. The time now is 06:52 AM. |
