I Put a Child Seat in an '88 Coupe
I know that from time to time the question about child seats pops up, so I thought I would post my solution that I implemented today.
I bought a Britax Boulevard 70 G3 at BabysR'Us. Britax Boulevard 70 G3 Convertible Car Seat - Cavalier - Britax - Babies "R" Us I initially tried it with the seatback removed, but it was reclined too far and my son had no room for his legs, so I replaced the seat back. However, when reinstalling the seat, I did not reattach the carpet on the back of the seat (you'll see why, below.) I am using the other side's seat belt as you can see here: ![]() With this car seat, when you use the opposite buckle, the seatbelt is fully extended and very tight, which removes the issues some have with the fact that our retractors are not ALR. Also, I like that this seat has built in locks, so you don't have to use the H Clip that other seats require. These locks clamp down on both pieces of the seatbelt (shoulder and lap) as you feed it through the back tunnel. There is one at the entry of the tunnel and another at the exit. You can see the entry lock here: ![]() Even though it was pretty tight, it could still tip forward a bit, so I felt like it needed an upper tether. For this I fed the tether down behind the seat back (this is why you need to detach the carpet) and clipped the tether to the bolt that normally holds the seatbelt receptacle. I removed the seatbelt receptacle, since I was not using it, loosened the bolt, attached the tether clip and tightened it back down. You can see the tether attached to the bolt here: ![]() And in the first picture above, you can see the buckle and the tether strap routed under the setback All in all, I am really happy with this setup. With this setup I am able to use all factory mounting points, which I think is a plus. And it is in there really solidly, this seat is not going anywhere. The passenger seat does have to be all the way forward, but that is fine for us (my wife is only 5'2"). And my son likes it too! Of course, what works for me may not work for you, so I encourage you all to do what you think is best for your car and your situation.
Andrew 1987 Carrera Cabriolet 1988 Carrera Coupe (RIP) Gone are the days we stopped to decide where we should go......we just ride. Last edited by Dooodahman; 02-24-2013 at 07:32 PM.. |
Great post,
Just to be clear do you have 3 points or only lap belts? Could you post a picture of the whole setup? Christian |
photos
Here are a couple (lousy indoor iPhone) photos of the seat installed:
Andrew 1987 Carrera Cabriolet 1988 Carrera Coupe (RIP) Gone are the days we stopped to decide where we should go......we just ride. |
I have a Recaro child seat in my 1988 Targa installed. There is enough room, I can even put it behind the drivers seat. Attachment is on the normal legal way like in any car with the three-point seat-belt:
![]() ![]() With a second child being born in April, I would ask if someone has experiences with using a baby seat like a Maxi Cosi (cabriofix) I can install it behind the passenger seat, but the passenger seat has to be all in the front. I was thinking about removing the back of the rear-seat for 2 years. |
But with a rear facing, it may have some benefit of extra leg room for the child, so I would try both ways. Hope that helps.
PS: It is also interesting that that Recaro booster fits in your tagra...
I have ProSPORTs in both of my other cars, which I love. But the seat base didn't even come close to fitting in the '88, and I want my three year old to still be in a 5 point harness, so your booster is not an option for me right now.
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
