-   -   Am I missing something? Heat backdate. (http://forums.pelicanparts.com/porsche-911-technical-forum/736162-am-i-missing-something-heat-backdate.html)
seymore 02-25-2013 10:00 PM
I have read a bunch of threads about backdating the heat on my 82 SC.
Am I missing something...
All that is needed are the pieces on the left and right of the fan and then run the heater hoses through the same holes down to the heat exchangers?
What are the parts on the side of the fan called so I can buy them.
Thanks guys and sorry if this has been covered a 100 times.
James Brown 02-25-2013 10:34 PM
930-106-321-01-PH
Left Side Heater Duct, 911 (1965-74) (1975-89 for backdated heater) NOTE: May need to be tapped with hammer near mounting screws to achieve optimal fit. [More Info]
$94.95
911-106-322-01-PH
Right Side Heater Duct, 911 (1965-74) (1975-89 for backdated heater) NOTE: Will require modification for cars with air conditioning [More Info]
$89.95
those are the 2 parts needed along with the hoses. some fitting around the distributor and if you keep the A/C, a little more fitting. SSI heat exchangers would be a good addition, they really pump out the heat.
911Freak 02-25-2013 10:35 PM
Heat Ducts
You need two of them, one left and one right
Pelican Parts - Product Information: 930-106-321-01-PH
Pelican Parts - Product Information: 911-106-322-01-PH
and the hoses, SCAT makes some nice aircraft quality
check the classified ads, they show up from time to time
timmy2 02-25-2013 10:36 PM
Heater ducts. This page has them:
Porsche 911 & Carrera Heating & Ventilation - Page 2
There are tech articles on doing it as well.
Aircraft spruce has the 2-1/2" sceet or scat hose you'll want as well.
seymore 02-25-2013 10:44 PM
Thanks guys. I do have SSI's so thats a plus I guess.
kiwiokie 02-26-2013 04:57 AM
You may also want to buy the square piece of engine tin through which the heater duct hose passes on the driver's side. On your SC this will have no hole for the hose.
will hung 02-26-2013 05:37 AM
This thread deals with the other issues that you rarely see discussed in heater backdate threads.
http://forums.pelicanparts.com/porsche-911-technical-forum/734741-heater-backdate-78sc.html
bgyglfr 02-26-2013 05:41 AM
I have all of those parts aside from the vent hose left over from my build. PM me if you want them.
Kirk
seymore 02-26-2013 01:43 PM
Can I not reuse the hot air duct I have now?
James Brown 02-26-2013 04:47 PM
yes you can
seymore 02-26-2013 04:55 PM
Thanks James, Just waiting to find a pair of used fan ducts now. Anybody?
Oh Haha 02-26-2013 04:59 PM
Be sure to buy hose that is very flexible for the heat exchanger to duct connections.
I used some of the original style aluminum hose for my backdate and it was difficult to make the bends.
I believe the orange Scat hose works best.
seymore 02-26-2013 05:03 PM
I was looking for new hose but I really don't want orange. I would prefer red or deep black. But didnt see any.
dipso 02-26-2013 06:34 PM
Heres a black one. Pelican Parts - Product Information: 901-211-195-01-M260
Here's the page. Porsche 911 & Carrera Heating & Ventilation - Page 1
Dont know why it says left side only. I have them on both sides.
seymore 02-26-2013 07:04 PM
Dipso, I have some of that already that im going to try to use. The one that goes all the way across the engine to the blower I will just cut and attach to the right side. Should be pretty easy.
timmy2 02-26-2013 07:05 PM
I originally used the hose posted above for my backdate. Doesn't shape very well for the bends you'll need on the left side. It lasted a year. You can't remove it without wrecking it due to the aluminum liner. I now have the orange stuff.
will hung 02-27-2013 05:28 AM
I also tried to reuse the hose that ran the width of my engine compartment. It tough to cut cleanly to length, and then even harder to get bent right to connect at the heat exchanger. I ended up getting the orange hose from Scat. They might have black hose. Give them a look.
SilberUrS6 02-27-2013 10:10 AM
On my 3.2, I need that as well, correct? ISTR that there is no hole for the hose to pass through...
DaddyGlenn 02-27-2013 10:56 AM
The hose that runs across the engine is 50mm in diameter. The hose on the left is 60mm as are all of the connections on the SSIs. If you use the long hose you have you will need to retain the adapters.
But you can ignore all of this if a PO tossed the adapters and used 60mm hose everywhere.
seymore 02-28-2013 09:27 PM
Does anyone know the part number or name of the engine tin that the hose goes through on the driver side?
