The Bavarian
How to test Auxiliary Air Valve
While stripping down my '81 SC engine (930/16) for chasing oil and vacuum leaks, I wondered how I can bench test the AAV.
Thanks, Manfred
Old 03-22-2013, 09:30 AM
T77911S's Avatar
with a hand vac pump. you have to cover one side with your hand. my pump came with big rubber fitting that i was able to use. i think it only works when pulled on one side. it was a bit tough to do.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-22-2013, 10:33 AM
The Bavarian
Thanks T77911S, I wil try that.
- Manfred
Old 03-22-2013, 09:56 PM
Jim Williams's Avatar
How to test the AAV
You can use a Mity-Vac and a 90˚ spark plug boot per the attached photo. The vacuum has to be pulled on the connection as shown and the other connector covered until a good vacuum is showing (6"-8"). Then release the finger seal and the vacuum should remain. A very slow drop in vacuum is still a passing grade as the vacuum is being continually replenished by the engine.
There are other ways to test, but they require disconnecting and plugging the hose ends, then starting the engine and comparing the way it idles with how it idled before the plugging of the hoses. So you may as well remove it to check it and know for sure.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 03-23-2013, 06:44 AM
The Bavarian
Jim and T77911S,
thanks for the explanation. I did the test as per what you described and it passed. One less part to care about
- Manfred
Old 03-23-2013, 10:37 AM
