Where to mount front seatbelt inertia?
Hi. I'm looking for photos of where members have mounted an inertia style (retractable) front seat belt in their early Porsches, I have a 1970 911Targa and would like some idea on where to mount them. Thanks.....
I'm interested too. Anybody done this? If so, please share the info.
Gents,
Here's a picture of my 70 targa. You should find recesses and bolt holes awaiting you behind your rear side panels. I'm not sure when it began, but from 1970 at least the cars were made ready to accept these. http://forums.pelicanparts.com/uploa...1361973933.jpg Good luck, Mike |
Thanks Mike, I'll get that panel off and take a look....
front seatbelt mounting
Hi Mike, thanks for the info. I took the panel off, and there you go, a recess for the inertia and a threaded hole for the bolt! Next question? Does the inertia go on the face of the panel or behind it? If it goes on the face will the panel not deform, and if it goes behind it won't go back on? I'm guessing some alterations to the panel will need to be made? Thanks Mike.......
Like Harry said. There's a plastic sleeve/insert that you might need to get for a conversion. Here's a pic:
http://forums.pelicanparts.com/uploa...1362153283.jpg |
seat belt guides
Thanks for all the info, this really is a great forum with very enthusiastic and helpfull members! Ok, so onto the guides. Does anybody out there have a pair? What is the part no or correct name? Many thanks....
| All times are GMT -8. The time now is 07:06 AM. |
