-   -   Alternator rebuild- While I'm in there list (http://forums.pelicanparts.com/porsche-911-technical-forum/736403-alternator-rebuild-while-im-there-list.html)
ned903 02-27-2013 09:33 AM
I'm getting ready to remove the alternator on my 87 911 coupe for a rebuild to correct an overcharging problem. I'll have bearings and bushes replaced while it’s out. Anything else that is worth doing while I have the alternator and fan, etc out?
ClickClickBoom 02-27-2013 09:40 AM
Full suspension rebuild?
PCA7GGR 02-27-2013 10:20 AM
A good shop will replace all of not most wear items on the alternator, including diode.
Spray the fan housing with a light coat of Rustoleum Matte Nickel Metallic brilliant metal finish - rattle can paint. Or a similar finish.
DaddyGlenn 02-27-2013 10:49 AM
That and a 3.6 swap. :D
Seriously though,
  • Vacuum out any debris that has collected in the fan housing
  • Refinish the fan and housing (color coordinated, of course)
  • New fan belt
DRACO A5OG 02-27-2013 01:58 PM
You guys kill me. lol
okay, check the ground wire for cracks or looseness or fouled connection, clean or replace if needed.
check for debris build up on top of the cylinder heads, clean and vacuum or blow it out the heads will cool better. That is pretty much all you can do wyait.
fancy ups would be powder coating or polish the fan and or housing ( you can check for cracks, I used QBond to help the cracks, but if you powder coat it will just melt off )
ned903 02-27-2013 03:17 PM
I appreciate the suggestions (meaningful and, well, less so)! I needed a couple of laughs as I was planning on driving the car to Austin tomorrow for the Grand Am race. That's out, so I'm ordering my parts so I can get started when I return.
Thanks again!
Jdub 02-27-2013 04:28 PM
Maybe change the sound pad, if needed?
