-   -   Identify Rotor (http://forums.pelicanparts.com/porsche-911-technical-forum/736586-identify-rotor.html)
GaryDG 02-28-2013 09:56 AM
Identify Rotor
RoW '83 here.
I went to change my rotor and rotor on my distributor is different than the new one from the host. I tried to match it to others on PParts but I can't seem to find a match.
Any ideas?
http://forums.pelicanparts.com/uploa...1362077661.jpg
catuck 02-28-2013 10:03 AM
Rev limiter on old one, not on new one (I think).
steve911T 02-28-2013 03:51 PM
You are exactly right. Stops those annoying shut downs at 6200 rpm. Steve
GaryDG 03-01-2013 07:39 AM
Thanks guys.
The PParts shows that the Rev Limiting Rotors apply to 74-77 911's. So they must work on
'83's?
To remove the Rev Limiting Rotor, just pull it straight up, like most rotors?
steve911T 03-01-2013 07:52 AM
I have a rev limiting rotor on my 89 and it is probably a good thing, it pulls straight up and when putting it back in, do not force it or it will cost you around $30 to replace. Been there, done that. Steve
GaryDG 03-01-2013 07:57 AM
Thanks Steve
So the Rev Limiting Rotor our host sells is good for '83's and '89's (probably 78-89)?
bkreigsr 03-01-2013 08:08 AM
the rev limiters came in three flavors up to 7,300 rpm
look for the limit stamped on the underside
you can disable it by removing the slider and spring if you have a lower 6,200 one.
Bill K
trak ratt 03-01-2013 08:29 AM
So are you guys saying the you think the US SC rotor will work on a ROW SC? I understand that the US one does not have a built in rev limiter. IIRC the ROW rotors are quite a bit more $$$ than US ones.
catuck 03-01-2013 08:42 AM
I'm wondering if the '83 doesn't have a rev limiter built into the ignition somewhere else anyway, and won't be needed in the rotor?
