-   -   Radio Install power source (http://forums.pelicanparts.com/porsche-911-technical-forum/736676-radio-install-power-source.html)
wolds 03-01-2013 05:15 AM
I'm getting ready to install a new radio in my car to replace the old after market radio. The previous install was questionable and I'm trying to figure out where the radio sources its 12VDC and power for memory from. I looked in my Bentley, but I don't see a reference to the radio in it. I figure I'd piggieback the memory 12VDC off the clock and I could take the source 12VDC off the light switch, but I'd just as soon wire this as the factory did. Any suggestions?
schumicat 03-01-2013 05:48 AM
host site has factory wiring diagrams which will tell you wire colors for power/switched power than run to radio. but like you say you can just get it from any available source.
Andy911sc 03-01-2013 05:59 AM
There should already be wires down there. Get yourself a voltmeter and set it to the chirp mode when power is detected. Make sure you have a good ground and some gator clips, so you can do it hands free. Ground wire is obviously the brown. Speaker wires are obvious also. Just see which one has power without the key in and make sure the other has power on/off with the key to on position. No need to start the car. I might have some close up pictures on my thread
wolds 03-01-2013 06:03 AM
Thanks for the info guys.
Andy911sc 03-01-2013 06:10 AM
I have confidence in you. Just take your time and if you are unsure, post some pics. We will try and point you in the right direction. I used to do custom stereo installations back in high school as a side business. That money got me through my first year of college loan free.
Nickshu 03-01-2013 06:10 AM
There should be a yellow w/ red stripe wire that is 12v+ for the radio in there somewhere. HOWEVER your wire may be red, from reading old threads there seems to be some variation here on different 911's with no real consistency, some have radio wires that are yellow/red and some have solid red.
The ground wire (brown) runs across from the MPIII ground area which runs together w/ the headlight switch harness and grounds in the frunk, just forward of the back of the fuel/oil gauge.
This may help:
http://forums.pelicanparts.com/porsche-911-technical-forum/726456-one-these-factory-radio-stereo-ground-wire.html
Good luck!
wolds 03-01-2013 07:03 AM
Thanks, I just printed off the wiring diagram from the host. Looks like the radio gets 12VDC from the ignition switch and should be a yellow wire if I'm interpreting this right.
nineball 03-01-2013 11:38 AM
typically constant is yellow and switched is red but you never know what you are getting into when someone else has "worked" on it before. your best bet is a multimeter and a beer :)
Andy911sc 03-01-2013 11:42 AM
best advice ever.... Multimeter and a BEER! and if you get stuck another BEER wouldn't hurt. I know I downed a few when I was working on mine.
wolds 03-01-2013 12:20 PM
How much beer?
nineball 03-01-2013 12:27 PM
Originally Posted by wolds (Post 7303634)
How much beer?
enough
nettles503 03-01-2013 12:40 PM
Originally Posted by nineball (Post 7303650)
enough
No such thing. http://forums.pelicanparts.com/support/smileys/wat6.gif
nineball 03-01-2013 12:49 PM
of course there is, i just haven't reached that point yet. still trying though, especially on the weekends.
Nickshu 03-01-2013 12:58 PM
Oh sorry, It's either solid Yellow or Yellow w/ red stripe.
Not RED as I said above....my memory failed me!
wolds 03-01-2013 01:37 PM
10-4, I'll grab a beer and my DVM tomorrow and go look, right after I clean my windshield channel in preparation for the windshield install next week.
