-   -   weber mod epoxy (http://forums.pelicanparts.com/porsche-911-technical-forum/736694-weber-mod-epoxy.html)
tcramer 03-01-2013 07:29 AM
weber mod epoxy
For those of you who have done the float bowl standoff mod,which epoxy are you using to glue the dam in place.I'm reading that JB weld won't stand up to ethanol blended gas.Thanks,T.C.
chris_seven 03-01-2013 09:16 AM
Masterbond EP41S-1
Walt Fricke 03-01-2013 04:50 PM
I just used something from the local hardware store. It has worked for years and years, always bathed in gasoline, including, as of late, gas with 10% or so ethanol.
timmy2 03-01-2013 05:11 PM
2 part Gas tank repair epoxy should work.
TimT 03-01-2013 05:31 PM
I have used Marine-tex in the past
