I need help with a Speedo problem on a 1976 911
Hello everyone.
A little background first. I have a 1976 911 that I did a 3.0 motor swap on. Everything works fine besides speedo.
The speedo works fine until you turn on the headlights. Then the speedo goes to zero. I have no idea why. Once again , driving during the day without headlights, speedo works perfectly , then when you turn on the headlights. Blammo, the speedo stops working and indicates zero with no movement.
Any help would be much appreciated.
Cheers,
Darren E Hall
TEL: 406-471-5883
email: ffsportacarmg@hotmail.com
1963 356B Coupe
1967 Porsche 911 Coiupe
1968 porsche 911 COupe
1970 Porsche 911E coupe
1976 Porsche 911s
Old 03-03-2013, 09:32 AM
ASE Master Tech - 35 yrs
larrym's Avatar
just guessing - i'd be looking for an accidental connection between the speedo signal wire and the ignition switch wire that goes to the light switch
get a good oem wiring diagram for both years cars - from factory manual is best - blow em up to table top size at Kinko's et al & follow the routing of all the wires now connected to it with an ohmmeter
i am dealing with a similar dash wiring problem and today i found a P.O. had connected several wires all together that should have been independent
, and that some patching had been done that resulted in "correct color" wire being attached downstream to a different color wire with a different purpose, and that "wrong wire" was connected to the light switch, shorting out the circuit every time the lights were turned on
- that can drive us nuts
good luck
ps - check this thread for ideas 1968 SWB Turn signal/park lamp operation
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 03-04-2013, 07:43 PM
scarceller's Avatar
Check the ground on the speedo. A lot of these type of issues are bad grounds.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-04-2013, 07:54 PM
