-   -   Another Bentley Error ? (http://forums.pelicanparts.com/porsche-911-technical-forum/73707-another-bentley-error.html)
cary 07-06-2002 11:06 AM
Putting the engine back in my car. Installing my new sport motor mounts. Went to put them in the transmission cross member and.......... Bently calls for 56lbs. on that M8 bolt and nut combo.
No Way ........It calls for 18lbs. on the body ones in the back.
Can't find the spec in my Porsche Factory manuals.
Where would I find that info. Someone that's BTDT.
TIA
rstoll 07-06-2002 11:24 AM
Sounds like an error to me. I believe you should go with the 18 lbs.
Early_S_Man 07-06-2002 12:15 PM
It is the M12 bolts through the center of the mounts that get 59 lb-ft ... the M8 bolts to the transaxle crossmember (or body in the case of the rear mounts) still get 18 lb-ft as usual!
Wayne 962 07-06-2002 12:26 PM
Yup, just to clarify, the M12s are the two big ones, the M8s are the four small ones...
-Wayne
cary 07-06-2002 01:03 PM
That's what I thought, and did. But just wanted to make sure.
Both the SC and Carrera book are the same and wrong.
Wayne my e-mail notification isn't flying.
Warren I did copy off your hardware torque chart.........but left it at work.
