Local Mad Scientist
Finally broke the clutch cable
Well, my mechanic warned me that it was stretched and old. The clutch cable finally snapped. I was trying to baby it. At least it didn't happen in traffic.
So I'm compiling a list a while I am in there parts. 1. Clutch Cable 2. Omega spring 3. Positioning lever spring 4. All new springs and bushings in the pedal cluster Anything else I should look at or think about?
1982 Porsche 911sc 2009 Jeep Grand Cherokee Laredo X CPA-PCA Member Since 2012 |
Transmission mounts?
Local Mad Scientist
good idea, but my mounts are still in really decent shape
Go with the bronzies for the pedal cluster!
After I did my cable and pedal cluster rebuild in my 911, the clutch feels fantastic. I have yet to drive it, but the feel of the pedal is so smooth. No need to replace the springs in the pedal cluster if they are decent shape (they are a bit pricey). They are big and tough springs. Do some rust treatment under the pedals while you have them out. (RWebb advised me to do this) Make sure your floorboard and rubber clutch pedal stop are in good shape. I'm pulling the wood back out this weekend to glue where it is starting to separate a bit, and to give it a coat of paint...
Dustin |
Dan '86 Carrera coupe |
Soak the bolts good with PB Blaster ahead of time.
I broke one (inside on the floor) getting my pedal assembly out.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Local Mad Scientist
Any issues with sand blasting all the black pedal components and respraying with a black primer? I am also replacing the speed sending unit while I am down there. Went out on me a few months back. I have been reading 5 - 10 mph slower on the gauge then what I am actually doing. Thankfully I have a smart phone with a gps speedo app that is surprisingly really accurate.
Local Mad Scientist
Thanks for the reminder pete. With the mouse nest that was down there, I am sure those nuts and bolts aren't looking too healthy.
Local Mad Scientist
Local Mad Scientist
As always, I will take pictures and post them all for people to look at. We all know threads are pointless without pictures.
Local Mad Scientist
Can't wait to dig into this project
You'll be glad you did all of this work when you see and feel the results!
Dustin |
Senior Member
I performed the entire process from rebuilding the pedal cluster right out to replacing the cable and omega spring. The difference in pedal feel was amazing - you will be very happy you did this.
Hopefully you have not ovalled the clutch pedal shaft "ear" as per the post link above. Also, search on Peter Zimmerman's advice to me about using plastic instead of the brass I ended up using. Otherwise, a great project with very rewarding results!
'78 Targa in Minerva Blue |
Local Mad Scientist
If it is the same advice I am thinking of, it is to warn you of a failing MC. (The brake fluid destroys the plastic bushings, and lets you know of a problem. I stick with checking the fluid level.
Dustin |
Senior Member
Andy - Advanced Search (Plastic Bushing + Peter Zimmermann) is your friend:
Clutch cable issue - 1982 911SC
Some pics...
![]() ![]() ![]() For brush-on paint, it came out fairly well.
Dustin |
Local Mad Scientist
That looks really good. I always pay attention to my fluid levels and other signs when driving. With that said, Is the feel noticeably better with bronze bushings or not really much different. As the son of a tool maker I tend to swing on the side of using a soft metal as a bushing over plastic. A well maintained machine or component will last many, many years.
the bushings definitely feel better and wont bind or get brittle and break like the plastic ones.
taking it apart and replacing the bushings is pretty easy... |
![]() My car had bronze bushings already installed, however they were quite old and lacked lubrication. The bronze bushing for the clutch arm where the clevis pin goes through was almost gone. With all new bronze bushings and some spray white lithium grease, I can't imagine a better pedal feel.
Dustin |
