1983Cabrio
1983Cabrio's Avatar
1983 SC Hot Start Problem
I've got another problem with my "new" 1983 911 SC. Starts cold fine. (sputters a little, but gets up to speed). If I drive the car up to temp and shut it off, it takes at least 2 minutes to start. I smell burned exhaust, but it doesn't even pop. I could run the battery OUT by turning the key. Eventually (with a little gas) it sputters to life, and then runs fine. Here's what I've done. New Fuel Pump, Fuel Filter, Air Filter, Accumulator, 6 plugs, dist cap and rotor. New injector "O" rings, and two new injectors. NOTHING WORKS! Help?
Old 03-01-2013, 06:04 PM
T77911S's Avatar
mixture could be way off.
CSV could be on when trying to start. would not think it is on all the time because it would run very rich, but check it anyway.
check valve. depending on how long it is off before you try to start it again. if you turn it off, then try to start it, not like likely the check valve. if it is 30 minutes or so, the check valve could be bad.
on the lesser likely side, due to it would effect driving, but you did not say how it drives, the plunger could be not dropping all the way down when you shut it off, making fuel dump into the engine.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-04-2013, 07:00 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Drop the $120 for a CIS pressure tester. Pelican Parts - Product Information: TOL-TA33865
You probably have a routine residual pressure leak - the leak causes a fall in residual fuel pressure in the lines to fall off when you shut off the car. How did it run before all the fuel system parts were installed? If it started when warm go back to all the parts replaced and check the connections.
Also, did you do the parts install or did a shop?
How much do you know about CIS? It's ok if you don't know squat cause none of us did either at one time. We can point you to some good info to read.
When you say "starts with a little gas" do you mean depressing the accelerator? I remember having to mash the pedal to the floor for about three start attempts (after ten without) to finally get a little cough from the engine and then it would finally catch - but really barely turning over, eventually it cleared out and ran great. A little embarrassing in the work parking lot. :-)
1981 911SC Targa
Old 03-04-2013, 07:20 AM
1983Cabrio
1983Cabrio's Avatar
When it is running, and/or when it starts up, the exhaust does have a strong burned fuel smell, enough to make your eyes water.
I put in all of the parts myself... am new to CIS, so I'll grab the pressure tester... your advice totally makes sense as yes, I step on the accelerator to make the car sputter to life after 4 or 5 start attempts.
Thank you guys for your help... been a Porsche fan since age 6, never had one til now!
Old 03-04-2013, 07:58 AM
1983Cabrio
1983Cabrio's Avatar
Oh, also the car runs really HOT. Almost to the red when warmed up... and when it is that temp, If I give it a lot of gas, it has that octane knock... but I only put premium gas in it... Related?
Old 03-04-2013, 08:00 AM
kodioneill's Avatar
Tune up, fuel pressure check, and possible fuel accumulator failure.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-04-2013, 08:08 AM
T77911S's Avatar
your timing could be messed up. stuck advance, or not set properly.
you should not runit that hot. find out what is going on. you could have a rats nest in the engine blocking air to the fins and cooler. you could have a stuck internal Tstat.
check fuel pressures be fore making any mixture adjustments.
RACE CAR:: sold
Old 03-04-2013, 09:42 AM
Timing sounds way off!
And I agree that it could be the fuel accumulator, thats what it was on mine!
Old 03-04-2013, 11:45 AM
scarceller's Avatar
First, Do NOT push this engine with much load if you hear knock!
From your description of hot operating temps you could have a nice size air leak that causing you to run lean.
You should never hear audible engine knock.
I owned a 75 911 that knocked like you described and it was not very long before I had a hole in a cylinder right at the edge where it meets the head!
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-04-2013, 12:11 PM
sounds like the dizzy is stuck advanced.
Old 03-04-2013, 12:39 PM
1983Cabrio
1983Cabrio's Avatar
Thank You will check all of the above... much appreciated.
Old 03-04-2013, 02:42 PM
