porsche 911 1974 pedal box assembly
i would like convert my pedal box (clutch brake throttle) liketo know if anyone has done a conversion and how. Circuit racing upgrade.
thanks
Your best bet would be to replace the one you have with an aftermarket assembly. It's been discussed here many times and there are two or three companies that have made them. Some are a little pricey. The throttle is a separate piece and I don't know what you gain by changing that.
If you end up buying an aftermarket pedal cluster, I might be a buyer for your stock one. Thanks, Jeff |
