Power window problem 81 911 sc RS door panel install
When I was changing the driver side door panel I made a mistake hooking up my window switches. When I tried to use the switch I heard a pop. I blew the 25A power window fuse, oops. I replaced the fuse and I want to sort out my window switch but it doesn't have power. What should my next move be? Relay? Thanks.
I did the same thing, so don't feel bad
Search for window switch wiring there is a post out there that has the correct wiring info in a couple of pics Thats how I fixed mine |
Here is the link
http://forums.pelicanparts.com/porsche-911-technical-forum/684583-ugh-drivers-side-window-switches.html the wire colors were a little off for my 83 but by process of elimination of the ones that are correct you can figure it out |
Awesome! Thanks for your help ThomO.
yeah deffinatly dont feel bad. i did the same thing....4 times. i guess this now give me a reason to update to the newer style fuses.
I still cannot get power to the switches. Would the next step be to replace the relay? Thanks.
I wouldnt think a relay would be hold you up in this case. are you sure you got the connections correct and replace with the correct size fuse?
You probably need new switches now.
I think I have the wires correct but im not 100%. I will try to rearrange them and see if it makes a difference. If they are wrong, it should just blow the fuse again right? Yes, I did replace the blown fuse with the right fuse and I got a couple extra just in case it happened again. Thanks.
yeah itll pop them again if you have them incorrect. this is per the bently manual.
on the drivers door: left window switch right window switch 1 blue red/ white 2 blue/ black red/ black 3 single red/ blue single red/ blue 4 brown brown 5 double red/ blue double red/ blue Passenger door 1 blue 2 blue/ black 3 red/ white 4 brown 5 red/black |
Winered : went through same problem as you (83sc) pass side switch, blowing fuses....finally popped off pass switch on drivers side looked at connections and repeated on other switch, no problems!!
| All times are GMT -8. The time now is 07:01 PM. |
