-   -   Lighted Key Assembly? (http://forums.pelicanparts.com/porsche-911-technical-forum/737549-lighted-key-assembly.html)
mooney265 03-06-2013 09:24 AM
When I popped this thing apart, all the parts went flying and not too sure how the copper "tab" on bottom of picture goes back in.
Can anyone help? Thanks!
http://forums.pelicanparts.com/uploa...1362590646.jpg
Justin@Athens 03-06-2013 10:36 AM
run the little copper piece almost parallel to the bulb base. It will wedge between the battery and the little gray rubber piece and the ends will fit in little recessed areas. Sorry no pic
mooney265 03-06-2013 10:50 AM
It's obvious, now.
I was trying to put the piece in "flat" and not "veritcal."
Thanks Justin!
iamtheari 03-06-2013 01:16 PM
I did the exact same thing and was worried I had broken it. I will say that taking the key apart and putting it back together improved the light. I flattened the end of the copper tab that had slightly bent before reassembly. I put a new battery in later for good measure, but even before doing so the switching action was dramatically improved just by everything being lined up right. (Before, it would flicker and give weak light.)
mooney265 03-06-2013 05:50 PM
I'm all over it. Thanks for the replies. I'll look into the LED option, too. Anyone have the link to the thread?
** EDIT - - I found the link: http://www.porscheresource.com/how-to/led_key_light_conversion.html
